Old Fri, May 7th, 2010, 10:40 PM
Goats Goats is offline
Goats is on a distinguished road
Default 1st drive great than died on 2ed
Like the title says the first drive was awesome had a alittle issue and not having it clean enough but on the PCM and after I got home like 1hr later I started it and it died like while it was warming up and it didn't restart cause when I was turning the key back on to start it the wait to start didn't come on just like before when I was installing it and there maybe a chance I cleaned it to well cause I played with it and got it to work and if I touch it a certan way it will die and also I got it to work the service engine light is on now also but it still works and do u think it's a connection issue? and I don't have a code reader so I can't tell u the code sorry for the run on sentence
Old Sat, May 8th, 2010, 12:09 AM
If changing the chip position in the PCM makes it work again then I would say it would have to be a bad connection.
Is there any copper showing on the terminals on the circuit board ?
Does the chip have a firm connection with the board?
Old Sat, May 8th, 2010, 03:48 PM
i got it now one of the pins wasnt clean enough
Old Sat, May 8th, 2010, 06:41 PM
cj45lc cj45lc is offline
Good deal. I just put mine in thursday & really like the tunes the 120 runs & shifts great on my truck. What tunes did you get & which do you like the best?
Old Sat, May 8th, 2010, 07:18 PM
1.stock
2.wisper
3.40 tow
4.80 tow
5.80 dd
6.120 race
i havent towed any thing yet and ive just been using the 80 dd for now
Old Sat, May 8th, 2010, 08:02 PM
Just wait til you try the 120. I like everything about it, shifts, power, smoke if you want it. What else could a fellow want?
