Old Sat, May 8th, 2010, 01:38 PM
loner1's Avatar
loner1 loner1 is offline
Don K.
loner1 is on a distinguished road
Default Lost power while Shifting on the Fly
Anyone ever have this happen to them?
I pulled over to the side of the road to try to restart the engine, the only way it would start was to recycle the ignition key then it ran fine again.
My emissions and battery light came on when the truck quit.
Anyone have any ideas? The truck is a 2003 7.3 with a A.T.
Last edited by loner1; Sat, May 8th, 2010 at 06:06 PM. Reason: no spacing between the and Fly in title
Old Mon, July 5th, 2010, 09:45 PM
StrokeOfDarkness95 StrokeOfDarkness95 is offline
StrokeOfDarkness95 is on a distinguished road
I see alot of people that seem to have the same problem. I know thats not much help but mabye it will make you feel a bit better. I'd also like to know why this happens.
Old Mon, July 5th, 2010, 10:13 PM
This seems to be an older thread but I'll see if I can get Cody to explain.
Old Tue, July 6th, 2010, 10:19 AM
There are times that the PCM may be looking up a certain operating parameter from the memory right at the very instant that the chip calibration is changed. It doesn't really happen that often, surprisingly. It's not going to hurt anything when it happens, but it does happen occasionally. The newer trucks are more prone to it than the older ones only because there are far more things going on in at any given time with the newer ones. Consequently, if there does happen to be an interruption in the data fetching, the PCM says "What the ****?" and shuts down. Sometimes, if it's a recoverable error, the truck will simply hiccup and be on it's merry way. Other times, the PCM will not allow a quick reboot and shut the truck off completely. This is why it's better to switch the positions on the chip while coasting....there are very few things "going on" inside the PCM on a deceleration event.
Keep on truckin'!
