Old Mon, May 10th, 2010, 06:45 PM
cheepone2's Avatar
cheepone2 cheepone2 is offline
cheepone2 is on a distinguished road
Default Gryphon as code reader
What are the Gryphons capabilities as a code reader compared to other popular tuners/code readers?
Old Mon, May 10th, 2010, 06:53 PM
Its good for your truck and other similar trucks. For example, I could pull the code on 04-08 f150s if my truck was programmed back to stock. Anything outside of that bracket wont work.
But for just your truck it can pull any code that pops up so it is very usefull. I was having trouble with a remote starter and if it were not for the programmer I would have had to make a wreaker take my truck to the dealership for PATS issues.
Old Mon, May 10th, 2010, 11:14 PM
It reads the obdII can bus codes.
Just like the other programmers.
If you need to read body or tranny codes then a scanner with those options is needed.
Old Tue, May 11th, 2010, 07:07 PM
texas offroading
body codes?
Let's go Wheelin!!!
Old Tue, May 11th, 2010, 07:14 PM
I think it is for stuff like electrical shorts for the power windows and stuff.
I think the some stuff like the B1600 do show up. This is a code from the PATS that the signal isn't correct. This code is able to immobilize your vehicle.
Old Tue, May 11th, 2010, 07:26 PM
Yup! There's all kinds of different codes. Almost makes the idea of a tech who could listen and "feel" to diagnose a vehicle problem an obsolete concept. All we need now is a "smart" code reader. Then, we just remove and replace the part that's throwing the code.
Old Tue, May 11th, 2010, 07:29 PM
Bill would make a killing if he wrote software for the gryphons to do that.
Old Tue, May 11th, 2010, 10:09 PM
The CS/CTS might have enough memory but the original Gryphon does not.
Thats also why more memory is needed because in the 09+ f150'S they have 2 PCMs that talk to each other.
Old Wed, May 12th, 2010, 04:58 PM
texas offroading
I tend to use the listen/feel method alot, though i am not anywhere close to a tech. i just 'know' how my engine sounds/runs/feels etc. i think we all do to a degree. when i blew a plug a cpl months ago, i could def. hear a miss b4 it happened...didnt need a device to know that. lol
and...as far as DTC codes, in many cases its not 1 part thats called out but many. i was getting that p1153 code a while back and the possibilities were close to endless on that one. Believe it or not, since i went off-roading with longshot...that code has yet to pop-up agn...and its been almost a month.
glad i didnt spend money on any parts.
2 pcms??? ...all i can think is why? the only way that makes sense to me is if one were to be responsible for certain data and the other was for another category of data. why would you need 2pcms, if one dont work right the other is just gonna thor things off....maybe thats a question for ford, or mike rowe lol.
interesting thread...
Let's go Wheelin!!!
Old Wed, May 12th, 2010, 05:44 PM
Maybe you had some soot that was messing up the sensor and you either burned it off climbing up those hills or shook it off when you fell back down.
I think the 2 pcms might be for either the two settings (tow and regular) or one for the engine and one for the tranny. Still an interesting question.
