Old Sat, May 15th, 2010, 04:54 PM
sgg's Avatar
sgg sgg is offline
sgg is on a distinguished road
Default Possible turbo upgrade
Well, I was getting ready to install my chip and new gauges when I found out my turbo is blowing oil. So I'm thinking about upgrading to a 1.0 housing while I'm at it. Just worried that the EGTs will get too high while I'm towing, and that my tunes might not work with the change in turbo housing. What do you think?
Stacey G
95 F350 CC dually, 7.3l, auto, DIY intake, Rosewood Stage 1 injectors, 3" DP, 4" exhaust (no cat), EGT & boost gauges, 4.10 gears, Phoenix chip w/ 65hp Tow, 80hp DD and 100hp Performance
Old Sat, May 15th, 2010, 08:54 PM
As long as you can sacrifice a touch of high-rpm power, the 1.0 exhaust housing is great! No tuning changes necessary.
Old Sat, May 15th, 2010, 09:58 PM
sgg's Avatar
sgg sgg is offline
No egt issues to worry about?
Stacey G
Old Sat, May 15th, 2010, 10:34 PM
Not much more than you do already. Of course you'll have to keep an eye on them. I've done it to two trucks (neither with St. 1 injectors though) and never had anything but good things to say about either. Your compressor might not like you for it since it will be out of it's efficiency range under the higher boost.
Old Mon, June 14th, 2010, 07:06 AM
sgg's Avatar
sgg sgg is offline
OK... too much downtime, but I had a cracked bearing housing on the turbo and it was blowing oil into the intake as well as leaking oil. But thanks to Ron @ Ron's Turbo (awesome guy, superb service, knows what he's doing!!!), I've got it back together and installed my Phoenix. I knew it was going to be awesome, but MAN! 65hp Tow is cool. You can feel the extra torque, but it's mild other than the much delayed shift points. 80hp DD is really fun off the line. It blows out a lot of smoke (more than I really wanted) if you floor it off idle, and then takes off hard! 100hp Performance is AWESOME!!! Doesn't take off quite as hard as 80hp DD and not much smoke, but HOLD ON! It sets you back in the seat and doesn't let up as long as you keep the pedal down!!! 90mph in no time, and it still feels like it's just taking off!!! THAT'S WHAT I'M TALKING 'BOUT!!! Can't wait to get the 5th wheel behind it & see what that's like! Thanks guys! I don't think I could be more pleased with my setup!
Stacey G
