Old Fri, February 6th, 2009, 10:09 PM
pickemuptruck13 pickemuptruck13 is offline
pickemuptruck13 is on a distinguished road
Default Changing programs
do i need to return to stock when changing between 1 2 3 tunes or can i just switch. also i had of people unhooking the battery what is this for and how long does it take for the truck to make changes? Sorry for all the questions
Old Sat, February 7th, 2009, 01:43 AM
twintips_17's Avatar
Let the Mud come!!!
You do not have to return to stock. Every time you do that it will just take longer.
SUPERcrew
AF1, EDGE, and EFANS with Magnaflow Exhast SISO.
Expy Console and Rear Seat Swap! Eagle 16's with 285-75/16 ST's
Gryphon Tuner soon to have custom tunes by PHP!
Old Sat, February 7th, 2009, 09:37 AM
And, you don't have to unhook the battery either. If you DO unhook the battery, the truck's PCM will have to "relearn" it's idle and fuel trim strategies. This has been recommended by some if you do some serious modification that can effect the fuel mixture, such as installing a CAI.
Ultimately, I think, the PCM learns to cope with the new modification even if you didn't disconnect the battery, but disconnecting it speeds up the process (and forces you to reset your clock and radio presets).
But, leave the battery connected when installing your Gryphon or after programming the PCM.
The changes you make to the PCM are instantaneous. Once the programming is complete, you're good to go. Programming takes anywhere from about 30 sec up to several minutes depending on what you decide to do about Custom Options". You can read about Custom Options in the manual.
