Old Fri, May 21st, 2010, 02:02 PM
97Fone50 97Fone50 is offline
97Fone50 is on a distinguished road
Default error 150 help quick :)
i need help truck wont run right programmer wont see the PCM got any thought on fixing this....
Old Fri, May 21st, 2010, 03:39 PM
Cody,
It may be Kevin?
Old Fri, May 21st, 2010, 03:53 PM
Sorry!! I was busy answering two phone calls while juggling some information for Bill since he was outside programming a 6.0L.
You're right.
Old Fri, May 21st, 2010, 06:19 PM
Ok.... this is kevin im trying to do Firmware update there now but it says the firmware and Calibrations will not work together... what do i do i have to go outta town tomorrow!!
Old Fri, May 21st, 2010, 09:54 PM
97Fone50, when the programmer and everything is "On" but without the engine running, disconnect the programmer. Wait about 10 seconds and plug it back in. If you hex code shows up you should be good, if not then get back to us or try calling PHP.
Kevin, can you do one update at a time like the firmware then the calibrations? Also are you just updating canned calibrations or are you downloading custom tunes? If it is just canned then dont worry about them and just focus on the firmware.
Old Fri, May 21st, 2010, 10:19 PM
well from what im told from my brother who was the one driving he started the truck in a middle of a load of a Custom tune. He called you guys and you said i had to update the firmware now after that ..... he said the truck wont get over 10 mph. he said PHP told him to flash it back to stock.... witch is what its sittin on now
Old Fri, May 21st, 2010, 10:22 PM
Was the return to stock successful? Does it drive like a normal stock vehicle now?
Try just the firmware update. But only if the truck is running normal.
Haha, just noticed that 97Fone50 is kevin. Sorry about that
Old Fri, May 21st, 2010, 10:43 PM
he told me it went back to stock lol... didnt think much about it now i tryed doing update but it failed i just went out and it just programed back.. perfect... runs good :> thanks guys
Old Fri, May 21st, 2010, 10:48 PM
Ok, so everything is good now?
Old Fri, May 21st, 2010, 11:42 PM
You had better have a discussion with your bro.
"Hands Off" is what I'd tell him.
