Old Fri, July 16th, 2010, 05:53 PM
ncTidalWave ncTidalWave is offline
ncTidalWave is on a distinguished road
Default 2010 TSC/RSC/ESC Re-engage speed
I've got a 2010 FX4 and was wondering if you can bump up the re-engage speed of the RSC/ESC (right now is 35MPH) like you can the speed limiter. If not, is there any way to keep the TSC/RSC/ESC disabled permanently (other than removing fuses)? This really bugs me as it is. Thanks!
Old Sat, July 31st, 2010, 08:42 PM
anyone??
Old Sun, August 1st, 2010, 10:14 AM
This has been asked before on f150online. I think the answer was fuse removal is the only way. However, if that's the case, you SHOULD be able to wire in a cutout switch on the same line as the fuse.
This, or the fuse removal might produce a code though.
Old Sun, August 1st, 2010, 12:18 PM
martinoledad's Avatar
I emailed SCT because someone either on here or on fordf150.net asked the question about the Xcal. SCT said the the Xcal should be able to do it but they recommened Ford's way of doing it. Ive never tried it with mine or asked bill about it.
Old Sun, August 1st, 2010, 11:39 PM
Thanks a lot for the replies!
JackandJanet, thanks for the idea. I think if I can't get a more elegant solution I'll wind up putting in a a switch.
martinoledad, what is Ford's way of doing this? Thanks again.
EDIT: I searched F150Online already and couldn't find what Ford's solution is.
Old Mon, August 2nd, 2010, 10:55 AM
I was just talking about how you push the traction control button down for how ever many seconds and turn it off that way(which it comes back on, like you described above)....sorry i should have been more specific.
