Old Thu, August 26th, 2010, 02:27 AM
chappy's Avatar
chappy chappy is offline
chappy is on a distinguished road
Default rev limiter on 7.3
Hey I was just wondering what peoples rev limit is w/ Bills tunes.Mine never seems to hit one like a gasser does.Just stops pulling around 3-3100 rpm.Not sure if thats normal since friends have similar mods on obs and newer trucks different tuner and they go higher.They seem to rap out more even when reving in neutral.mine never does.Mods are 160 stage 1 single shots,adrenaline,boost fooler,idm mod,diy tymer intake,stacks no muffler
early 99 f250 powerstroke ddp stage 1's, php tuned, 6in 35's,tymer knock off,single stack,adrenaline and 05 f150 Custom tuned by PHP
Old Thu, August 26th, 2010, 10:35 AM
That's the nature of stock-ish injector nozzles and a restrictive turbine housing (it would be normal with a stock high pressure oil pump as well, but you've addressed that). These engines do not make any power above 3000 RPM without spending a ton of money on modifications.
We usually leave the stock fuel limiting in place because of these traits.
