Old Fri, September 17th, 2010, 11:30 AM
RMBC Freeride's Avatar
RMBC Freeride RMBC Freeride is offline
Projects...
RMBC Freeride is on a distinguished road
Default Can I get more tunes for my FU?
Recently installed my FU and loving it. Mostly running the 80DD and the 65-Tow (which is the only tow program I have and also the lowest HP tune in my list)
But I would really like to have the full range of tow programs available to me. Concerned because I tow everything from a small jetski trailer to 28' cabin cruisers. And I am usually towing in the mountains. So I'd really like to have the 25-Heavy Tow, 45-Tow and possibly the 80-Tow (less important) at my disposal. Have a trip coming up soon towing a 24' enclosed car-hauler and don't want to have to switch to (gasp!) stock to tow the heavy load.
Apparently there were very few tunes available for my hex code because I only got about 8 or 9 total, including the stock and no-start (was hoping for the 12-15 as mentioned in the product description)
Any help? Can I request these tunes to be built and added to my FU? Or can I switch to a different hex code to get all the tunes?
many thanks,
Neil
Neil
2002 Excursion LTD-Ultimate 4WD 7.3 PSD (major project - here): 35" Dura-Grapplers, V-codes+2.5" leveling kit front, C-code+extra leaf rear, 4" turbo-back, EBPV delete, 1.0AR Turbo, Bellowed up-pipes, DIY 6637, Wicked Wheel, 6.0 I/C&Trns/C, RiffRaff HPx, AIH & FRx, PHP FU Tunes!
DEARLY MISSED: '99 Lightning, '99 F-250 SD CC PSD
Old Fri, September 17th, 2010, 11:52 AM
I will get a few more built for you. Since you have an Excursion, the need for extreme weight towing tunes wasn't factored in.
I assume you have TNAA5Y7 as your FU hex code.
Old Fri, September 17th, 2010, 07:00 PM
Projects...
Awesome! Thanks Cody
Yes I have TNAA5Y7 hex
Its not so much that I will be towing extreme weight , but I might have heavy weight pulling over a high-mountain pass and would like to be able to "de-tune" to a minimum if temps get too high, etc. Thanks again!
PS: wouldn't mind having Smoke Show to blow out some ricers every now and then
Neil
Old Sat, September 18th, 2010, 10:00 AM
I made you one of those, too.
Old Sat, September 18th, 2010, 11:49 AM
Projects...
WOW! Popped open my Phoenix Flash this morning and bam! there's a whole slew of new tunes!!! I am safe to tow anything now! Wish I had a 12 position chip!!!
THANK YOU CODY & PHP!!! Incredible customer service!!!
Neil
Old Wed, September 29th, 2010, 10:59 AM
Projects...
I've been daily driving around in 40-Tow lately and really liking it. It doesnt have the top-end that 80DD has, but it does have a lot of punch, great for around town. And perhaps a bit better mileage since it does not pour on the fuel as much... we'll see after the next tank.
Neil
