Old Sat, September 25th, 2010, 09:02 PM
Unleashedford's Avatar
Unleashedford Unleashedford is offline
Big Burger
Unleashedford is on a distinguished road
Help Gas Pedal issue
here is some info
2004 f150 5.4 xlt 2wd with 3 custom tunes but only use custom 91 octane
so my issue is that when i press my gas pedal it doesnt go until i really press on it...so basically i have no clue what it is
for example: when i press the pedal it doesnt move or accelerate until i push the pedal down about 3/4 on an inch or inch...and it has a really late throttle responce...
i cant remember if i had this issue before the programmer or not....
can anyone please help?
Old Sun, September 26th, 2010, 01:27 PM
Big Burger
can anyone help?!
Old Sun, September 26th, 2010, 06:27 PM
It SOUNDS like the truck isn't downshifting or having the torque conver unlocking as soon as you'd like.
Try lowering the torque converter lock/unlock points for the 4th gear.
Old Sun, September 26th, 2010, 06:45 PM
Big Burger
i changed the tune back to stock and disconnected the gryphon and it responded a little better but still had a little hesitation
Old Sun, September 26th, 2010, 07:08 PM
How long had you been runing the custom tune? How long have you been running stock?
Old Sun, September 26th, 2010, 07:47 PM
I think there is a way to "recalibrate" the gas pedal, but I can't remember how to do it. (It may be in the owner's manual.) 88Racing posted on this several months back and it involves depressing the pedal all the way with the ignition ON and engine off maybe while you're reciting "Ford is God!" and so on. I don't have time to search for it right now - have to get to a Grandson's birthday.
Old Sun, September 26th, 2010, 08:58 PM
I remember it too, I'll see if I can find it.
Old Sun, September 26th, 2010, 09:03 PM
Ok, found the posts!
There's a relearn procedure.
KOEO.
Press down steadily till it bottoms out then back slowly to starting position 3 times.
Then turn off.
Then turn back on and start.
Going from memory here.
JMHO
[OP asks which pedal]
Gas pedal.
I'll look for the relearn proceedure.
[short time later]
Found it!
Just disconnect the battery for 5 minutes.
This will cause the PCM/ECM to reboot and the Keep Alive Memory to be erased so it can start a relearn proceedure.
You can do this while replacing the switch.
Peace!
Since it seems like the only thing you need to do is to try disconnecting the battery for 5 mins do clear the memory, then do that. The pedal pushing probably wont do anything but I copied it for refrence that these were the posts.
Old Sun, September 26th, 2010, 11:17 PM
Big Burger
i have done that like 5 times already and it doesnt seem to help, would i have to turn the gryphon back to stock then do this or?
Old Sun, September 26th, 2010, 11:18 PM
Big Burger
well tomorrow i am going to switch it back to stock for a week then switch it back and see what happens, maybe it might fix it? idk
