Old Tue, September 28th, 2010, 03:39 PM
Default Hitting Rev Limiter
What did I do wrong?
It will hit the limiter between shifts, only when wide open. Does not seem like it is the trans slipping, just wont shift.
Old Tue, September 28th, 2010, 04:02 PM
Do you have the WOT shift parameters set too high? RPM Anticipated shifts?
Old Tue, September 28th, 2010, 07:30 PM
WOT shifting is set for 3400 rpm, fuel limit should not really come in till around 3600ish.
I cannot find anything labeled "RPM Anticipated shifts", I did find RPM Maximum to Predict Upshifts - which is set to 1000 RPM.
Old Thu, March 31st, 2011, 10:40 PM
967.3L4x4's Avatar
967.3L4x4 967.3L4x4 is offline
Minotaur Newb
967.3L4x4 is on a distinguished road
Just wondering if you came up with anything on this. Mines doing the same thing, kind of like it shifts too softly for stage IIs and lets it over rev. Seems like the shits need to be harder and faster. This is a tune I got from Bill for the IIs so Im assuming anything the has to due with it engine wise should be pretty good and some tranny tuning should take care of it. I messed with some stuff a little but would like some guidance before I go too far. Any tips would be appreciative.
John
96 7.3L E4OD, Ext. Cab 22x,xxx miles
Intake, Exhaust, 6.0L IC,
4 Wheel Disc Brakes. Dana 60, Electric Fuel,
SD HPOP, 6" Miter cuts, 3" plenums
Rosewood Stage IIs, Built tranny.
Minotaur with some tunes from Bill
Planning: Traction bars, HPOP, Nitrous??
Old Thu, March 31st, 2011, 11:03 PM
Is the shift happening, but not holding?
If so try decreasing the Target Slip Time, or increasing the Trans. TV Pressure, or both for that particular shift.
Old Fri, April 1st, 2011, 05:22 PM
967.3L4x4's Avatar
Minotaur Newb
It defiantly seems like it tries to shift.
I couldn't find the target slip time, I read that in another post but couldn't find it. I did raise the TV pressure and it helped a little on the 1-2 shift but it still isn't right.
Old Fri, April 1st, 2011, 05:58 PM
Sorry bout that......
I just realized you are playing with an OBS....target slip time must not be an option for ya.
Old Fri, April 1st, 2011, 07:18 PM
967.3L4x4's Avatar
Minotaur Newb
Dang, any other ideas? All i really see the could speed up the shifts are the TV tables
Old Sat, April 2nd, 2011, 04:15 PM
Blowby's Avatar
Blowby Blowby is offline
Blowby is on a distinguished road
Order the BTS valve body and adjust the calibration plate for shift firmness. BTS valve body install.
F250 Reg Cab - 1,172 HP / DJ# / 11.56 Fuel Only / 10.94 Nitrous / Dyno Run 10-2009
Wide Open Performance - Engine, Chassis Build
Swamps Diesel Performance - Injectors & IDM
Gearhead Automotive Performance - Stage II Cam
Old Sat, April 2nd, 2011, 04:22 PM
Blowby's Avatar
The over run will increase as power increases, with Stage II's shoot for about -350/400 rpm from your actual target RPM. Also rev limiter will go the other way so add rpm to your target point. If you want 3600 input 3900 or so..... hope this helps.
