Old Wed, October 20th, 2010, 11:06 PM
dlaroche1 dlaroche1 is offline
dlaroche1 is on a distinguished road
Default Gryphon and Pheonix together?
Can I piggyback the pheonix with my gryphon? Truck has open 4" exhaust and built trans, but otherwise stock 7.3 2wd 2001 model. Thanks.
Old Wed, October 20th, 2010, 11:27 PM
the short answer, yes. but you can only use one to program(the pheonix) and then use the Gryphon as guages only. other than that I dont think there would be any problems
Old Thu, October 21st, 2010, 07:29 AM
IF YOU HAVE A CHIP IN THE PCM, DO NOT ATTEMPT A PROGRAMMING EVENT WITH THE GRYPHON!! You can run the two together but the only performance gain you will see will be from the Phoenix (or other chip) and you will get nothing from the programmer.
