Old Sat, November 6th, 2010, 04:17 PM
beck8440 beck8440 is offline
beck8440 is on a distinguished road
Default do they make one for a 09 f150 4.6 2valve
does anyone out there have an 09 f150 4.6L 2valve AND HAVE A GRYPON programmer. if you do can you let me know how well it works. or does it matter if you have a 2v or 3v
Old Sat, November 6th, 2010, 04:21 PM
shotgun's Avatar
shotgun shotgun is offline
Gryphon CTS
Both the Gryphon CS and CTS will work for the 09-10 4.6L 2V.
Power Hungry Performance - Gryphon™ CS & CTS - Gasoline
Old Sat, November 6th, 2010, 04:35 PM
do you have a 2v or know anyone that does? is it worth the money? dont want to be dissapointed.
Old Sat, November 6th, 2010, 05:05 PM
shotgun's Avatar
Gryphon CTS
I have the 5.4L.
Pretty sure the Edge website does list hp/tq gains for the 5.4 and 4.6, but not sure about 2V. Custom tunes should provide an improvement over the canned tunes.
Perhaps Bill or someone from PHP can answer the hp/tq questions.
Old Sat, November 6th, 2010, 06:22 PM
If you can provide the ECM code (either the 4 digit Box Code or the Ford part number) from the ECM, I can tell you without question if that particular vehicle is supported. To the best of my knowledge though, all the 4.6 and 5.4 engines are supported.
The PCM is located in the passenger side firewall. It has 3 connectors and 2-10mm bolts holding it in. The sticker with the part number/Box Code looks like this...
I apologize for the quality. My Blackberry SUCKS at taking pictures.
I hope this helps.
Old Sat, November 6th, 2010, 06:44 PM
PDS2 is the code is the first four like the ENP2 ON THE PIC
Old Sat, November 6th, 2010, 07:19 PM
A cursory inspection of the file list indicates that your particular code is supported.
Old Mon, November 8th, 2010, 03:26 PM
So are you 100% sure if I purchase from you guys I wont have any problems installing?
Last edited by Power Hungry; Mon, November 8th, 2010 at 03:41 PM. Reason: Youtube link was missing.
Old Mon, November 8th, 2010, 03:40 PM
To the best of my knowledge, there should be know problems at all.
