Old Mon, November 8th, 2010, 01:16 AM
Colt Colt is offline
Colt is on a distinguished road
Default Chip issues...
I wanted to post this here before I make a service ticket..
I've been running the chip for almost 2 months now.. When I first got it I was burning tunes left and right. Finally got them modified to my liking and left them alone for a month or so.. Had been working great..
I got my custom tunes for it the 5th, so I burned them and got ready to test drive the truck.. The check engine light just stayed on.. So I pulled the chip, checked the connections at the ECM to make sure they were clean, and they were.. Put it back in, still nothing, truck wont start and has no sensor feedback ( like the ECM was brain dead ).. Reburned several times with the same results.. I got it to finally work, I figured it must have been a bad connection.. As soon as I got done with the test drive and shut the truck off, I tried to start it back up, and nothing, just the CEL. I bet I messed with it for 20 mins, cleaning the contacts and so forth.. Finally it worked..
Yesterday I jumped in the truck, same thing, CEL light, no start.. Messed with it for 10 mins, pulling the chip in and out. Finally worked.. Today it was the same thing.. This time I used some electronics cleaner on it, first time I put the chip in it worked.. Got home, shut the truck off, then turned the key back on, nothing...
If I pull the chip out, and leave it out the truck will fire right up no problem.
I think it's something with the chip itself.. Otherwise you'd think the truck would be screwing up while driving.. My truck has a beefed up suspension, most of the time it's pulling a trailer. So when it's empty it's very rough. So you'd really think if it was a connection, the first few bumps you'd hit the truck would shut off or something, but it doesnt..
Any idea's?
'00 F-250 7.3 PSD Best truck ever made!
'05 F-350 6.0 PSD
'07 F-450 6.0 PSD
'79 Mustang Turbocharged 302, Aftermarket EFI 563 HP/ 657 TQ
'98 Mustang Stroked, Blown, Aftermarket EFI 498 HP/ 537 TQ
'99 Cobra, no engine ( petal power )
'97 Dodge Ram 1500, Turbocharged 408, Aftermarket EFI
I have far too many toys...
Old Mon, November 8th, 2010, 08:55 AM
Have you got ALL 6 POSITIONS filled with programs?
If you just get a CEL, turn the ignition off and back on again within 1-2 seconds. Does it work at that point?
Old Wed, November 10th, 2010, 02:19 AM
Do all of them need to be filled? If so, I wasn't aware that they needed to be ( is that documented anywhere? ).. I hope thats what the deal is.. It would make sense too, because I've always loaded 6 tunes on, where now I only have 4 on the chip.
Yeah if I turn the switch on and off a few times it will work. Just look for the wait to start light and you know it's good.. Sometimes it will work first time, other times it takes 5-10 trys..
'05 F-350 6.0 PSD
'07 F-450 6.0 PSD
Old Wed, November 10th, 2010, 05:40 AM
Yep, all 6 need to be filled. I fought chip issues for over a YEAR trying to figure out why I would have intermittent problems with the chip not waking up. Fill all 6 and I'm sure your troubles will disappear.
By the way, it has to do with the way the chip boots in certain positions regardless of where the switch is oriented at the time.
Old Wed, November 10th, 2010, 08:56 PM
That got it
I'll probably hit ya up soon on configuring a new map sensor in Minotaur if I cant figure it out, the stocker is about shot, thinkin it's been "overboosted" a few too many times.. It sits on 1 PSI at idle and on decel, I know it's not reading right going down the highway, pretty much just stays on 6 or 7, though you can hear the turbo spinning up and down... I'll buy a 4 bar sensor once I find a suitable one.
'05 F-350 6.0 PSD
'07 F-450 6.0 PSD
