Old Fri, December 24th, 2010, 11:12 PM
elkyss81 elkyss81 is offline
elkyss81 is on a distinguished road
Default Sold vehicle kept chip...install on another veh?
OK so I sold my F250 and am now looking at getting an Excursion...but I kept my chip when I sold the F250. I doubt the PCM codes will be the same seeing as how my F250 was a 6 speed. Can I just switch the PCM codes for my burner access files and be good to go or will I have to buy another FU package?
Old Sat, December 25th, 2010, 12:16 AM
New PCM code license for your FU will be $50.
Keep in mind that the Passive Anti-Theft System (PATS) will be disabled so the vehicle will start and run if the incorrect key is used to start the vehicle. You can easily unplug the PATS module to keep the "THEFT" light from blinking at you for a few minutes every time you start the vehicle.
