Old Tue, February 24th, 2009, 03:18 PM
Chris74's Avatar
Chris74 Chris74 is offline
AAA Rib Steak
Chris74 is on a distinguished road
Default Open loop in 87 performance tune??
I know Bill is away and he'll likely confirm this when he gets back.......but does anybody know if our trucks will go into open loop under say light to moderate acceleration. I mean while on one of Bill's custom 87 performance tunes (or even 91 or tow tune).
If so, at about what rpm would they do that? I assume it will immediately revert back to closed loop once you level out to say a 65mph cruise?
I know it's open immediately at WOT but I'm wondering with the custom tune if it opens up at say half throttle.
I'm getting my truck dynoed on Friday and plan to do atleast one partial throttle pull to check the a/f at a light load cruise as well.
08 FX4 CREW
K&N 63 series Intake
Magnaflow SI/DO exhaust
Custom tunes
Old Tue, February 24th, 2009, 04:32 PM
Dfishrmn's Avatar
Dfishrmn Dfishrmn is offline
Dfishrmn is on a distinguished road
There was some discussion on this subject in the thread "Torque Converter" in this forum. Bill indicated his tunes go into WOT at approx. 90-94% accelerator pedal position, at that point it is in open loop. Hope that helps.
2005 F150 XLT SuperCab 5.4L V8 4x4, 3.73 LS Rear end, Auto Spring 2" Leveling Kit, Gryphon tuner custom 87 Performance tune, AEM Panel Air filter with modified stock intake, 14" Magnaflow muffler
Old Tue, February 24th, 2009, 08:00 PM
Chris74's Avatar
AAA Rib Steak
right.....got it. thanks!
08 FX4 CREW
Custom tunes
Old Tue, February 24th, 2009, 08:11 PM
My limited understanding of all this is you are in closed loop as long as the engine is fully warmed up and you don't get into the WOT throttle position.
I've noticed, now that I've got a Gryphon updated to show "gears", that the torque converter WILL NOT lock until things are all warmed up.
Old Tue, February 24th, 2009, 08:33 PM
twintips_17's Avatar
Let the Mud come!!!
I read somewhere that the torque converter won’t lock until the transmission reaches over 100 degrees.
Driving in Montana I can tell that it defiantly takes a bit before it will lock due to the cold weather.
SUPERcrew
AF1, EDGE, and EFANS with Magnaflow Exhast SISO.
Expy Console and Rear Seat Swap! Eagle 16's with 285-75/16 ST's
Gryphon Tuner soon to have custom tunes by PHP!
