Old Fri, February 4th, 2011, 06:11 PM
cj45lc cj45lc is offline
Default Dreaded Dipstick Flange
Boys I got a buddy with a '99 7.3 & he has the leak at the flange where the dipstick goes into the oil pan. Ford says they'll fix it but they want to charge him to R&R the engine, I told him that's horsesh-t they where gonna do it w/o pulling the engine but charge him that just in case. I'm real close to telling him I'll do it if he pulls that heavy a$$ starter out of the way...lol I mean folks have replaced that o-ring successfully & they just put there pants on one leg at a time, right. Any thoughts??
Old Fri, February 4th, 2011, 07:12 PM
Look to see were its coming from there's seals inside and on the tube. I broke my tube and just replaced it very easy. Pull the tube and replace that seal on the tube. If it still leaks do a Google search there's a detailed way of changing everything without pulling the engine.
Old Fri, February 4th, 2011, 08:18 PM
OK Thanks bud
Old Fri, February 4th, 2011, 11:50 PM
AussieOiler's Avatar
AussieOiler AussieOiler is offline
AussieOiler is on a distinguished road
Default BE CAREFUL
G'day M8,
Try this: Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
7.3 oil dipstick leak?
If it's just this leak around the Dipstick tube itself then no real drama to fix.
Oil leak at dipstick tube flange fixed -with pics!.
However if it's the flange itself then be sure to study up on how to fix that flange 'O' ring. The second thread is a good right up with excellant pics.
Big, big drama if the dipstick holder gives the dreaded "ka-ploop" into the sump
Be careful.
Just hope it is only the Dipstick
Good luck,
Reg.
[/SIGPIC] Aussie 2005(US 2003)F-250 SD 4x4 7.3Ltr PS: AIS Intake,Zoodad,Cowl Hood,AIH delete,DIY CCV,PHP FU2 Chip,RiffRaff FRx,HPx & OCR,BTM Exhaust,HD rear spring set,Front leveler spring, Dual Tower shocks front,Tough Dog Damper,ARB Air Lockers Front & Rear,V10 Tranny cooler+OEM Cooler, BD Deep Pan,JWVB,Long Range Fuel Tank,Edge Evo2,VMS In Dash Nav. GVM(GVWR)Upgraded to 5,000k(LT Rated F350+).
Old Sat, February 5th, 2011, 11:05 AM
YouTube - 7.3L LONGEVITY LEAKS 2 OF 2
Old Sat, February 5th, 2011, 11:53 AM
Thanks fellas, I guess you could say I chickened out. I gave him Marty's phone # yesterday eve. Would be different if I was still living in Ga. & if I screwed up I had a buddy that could weld anything (dam man could weld ANYTHING). Hopefully Marty will take on the task...lol
