Old Wed, February 25th, 2009, 08:01 PM
drug delivery drug delivery is offline
drug delivery is on a distinguished road
Default f1 error and timing
Per an e-mail sent to Corey this morning.
I tried to load the 93 performance tune this morning but got the "f1" error. This error stayed on no matter what so I unplugged the Gryphon and plugged it back it. The Gryphon never went through the procedure where you see the program load and update from 0% to 100%, so I assume it never took. Prior to the error, I changed the timing since I only had 87 octane in the tank at that time.
My question is, was the time change saved or no?
When I plugged the Gryphon back in I returned the truck to the stock tune then loaded the 93 tune again without issue. This was later in the day. When I loaded the 93 tune the second time, I asked the programmer to go back to the previous setting, so I suppose this should have undone the timing change, but again, I just want to be sure.
I did follow the turn key on/off procedure but I don't recall if the error popped up before or after that.
thanks,
Phil
