Old Tue, February 15th, 2011, 02:54 PM
grantlshiell's Avatar
grantlshiell grantlshiell is offline
grantlshiell
grantlshiell is on a distinguished road
Default problem solved
Finally after a year i figured it out. After installing my pheonix chip i had throttle response problems with the higher horsepower tunes. They were always jerky in the lower rps to the point where it wasnt even drivable. This past weekend i changed the belt driven vacuum pump on the motor because the bearing was squealing. Low and behold my problem went away with the new pump. Does anyone knowwhy that pump would affect the throtle response? By the way i would have sold my truck by now without that chip!
1996 F-250 CrewCab PHP Pheonix 40,80,smoke,idle 6" stacks, intake and guages.
2002 Excursion pheonix 80, 120
Old Wed, February 16th, 2011, 11:43 AM
That's good.
It doesn't make any sense, but if the truck runs better now, then roll with it!
Old Thu, February 17th, 2011, 09:59 AM
Vacuum leaks can be a pia especially at lower rpms with a load applied....
So therefore if it was replaced with the bearing squealing then the seal already had gone south probably at the same time the bearing started to go but it wasn't making noise yet....
