Old Tue, March 3rd, 2009, 07:17 PM
Shorse Shorse is offline
Shorse is on a distinguished road
problem
So i had been driving around with the stock tune all day yesterday just to make my self feel better about spending 400 bucks on this programer. WHAT A DIFFERENCE! I will never go back...
well I program it when i get to school.. go to do the custom settings, and instead of reading 3.55 for gearing or 2424 for tire size... all it showed was +1 or -1... once it went up it would not come back down... so i hit menu to get out of it... Once i went into everything, it all looked different, so i turned the key off... then back on to try again.. same thing, so i programed any way with the previously loaded settings...
i go to drive ita few hours later.. it moved out of the parking spot, then it felt like it went into neutral, and my speedo was reading 120 and the gryphon was yelling at me telling me my speed was 120 cause i set it to warn me when i go over 70... i hit the brakes, and it droped back to 0... i then could hit the gas, and it would move 5 feet and shoot back up to over 100.....
so i pull over, turn it off, and back on... give it gas and she moved, with quite a bit of balls, felt normal... then it got above 5 mph and i lost all power.... it felt like the truck turned off, i went to turn it back on, and it was still running...
so i get out of the parking lot ( i was blocking traffic getting a lot of honks), pull over and set back to stock.... give her gas, and all is well....
i get a mile from my house and say WTH, i'll try it again... went to level 2 again, custom tuning ( axle, tire size) all were normal 3.55 and 2424 not +1 or +2 like before... so i went through and re-programed it AGAIN....
now it is fine...
However i just realized i need to go to the dealer Friday for warranty work, and will need to go through this all over again...
is this a 1 time deal, or do i need some type of update?
The truck was fully warmed up, all power sucking things were off... battery is fine... The truck is a 06 f-150 5.4 4x4 XLT ..
