Old Mon, April 25th, 2011, 12:04 PM
darrenFX4 darrenFX4 is offline
darrenFX4 is on a distinguished road
Default Went to change program, error code came up..
Ok have had my gryphon for several months and love it. I was changing my level and was doing a custom program (to input proper tire size) and this and Error code F1 came up saying, it does not support this calibration, which it always had. said update or call tech support.... not exactly sure what to do
Old Mon, April 25th, 2011, 12:31 PM
This is covered in the owner's manual under Troubleshooting.
1. Leave the ignition key in the ON position.
2. Disconnect the Gryphon at the OBDII port.
3. Plug the Gryphon back into the OBDII port.
4. After getting to the main screen, wait 15 seconds for needed parameters to be loaded.
If you still cannot program the PCM successfully, contact PHP for assistance.
Old Mon, April 25th, 2011, 01:20 PM
Ahh, 10-4 I apologize, I couldn't find my PDF manual on my comp (I found it now). I apologize. Thanks for the reply Jack.
Old Mon, April 25th, 2011, 01:24 PM
It's fine Darren - hope the problem goes away.
Old Mon, April 25th, 2011, 04:10 PM
yup prob solved!
Old Mon, April 25th, 2011, 04:28 PM
Good to hear, Darren -
We're not like some forums. If you have questions, it never hurts to ask. I only said the answer was in the manual to remind others who might have a similar problem.
Old Thu, January 12th, 2012, 08:51 PM
madpirahna madpirahna is offline
madpirahna is on a distinguished road
and it worked because it just happened to me and I came on the forum and used the search function.
Thank, I was worried for a minute.
