Old Sun, June 19th, 2011, 11:36 PM
hampsterzone's Avatar
Come Get Some
6" Pro Comp Lift
I was finally able to get the lift I always wanted. It is awesome! The only issue was the 4 wheel vaccum lines not being long enough. Had to make custom extentions. For anyone using a 3" reddi lift w/ a leveling kit. Be careful because it ruined my upper ball joints. I had to replace the upper arms and they cost $179.99 a piece. But they are a very nice addition to the lift. I left the leveling kit in w/ the 6" lift to level out with the rear add a leaf. Making my over all lift 8". The arms are perfectly matched to stock measurements. Now I could run 37" tires but stayed with the 35". The ride is nicer than exspected. Does anyone know what psi I should have in the tires? They say 50 psi max cold. But I want the proper psi for proper wear and fuel mileage. Thanks.
2nd place is 1st's loser!
Old Mon, June 20th, 2011, 03:14 PM
Tire pressure is going to rely completely on the weight you have on the truck and what you're using it for.
I have had great results with chalk and a concrete pad. Inflate/deflate each tire until you get a full and even contact patch on the ground.
My first '95 Powerstroke with 49" tires took about 15 PSI in the rear and 22 PSI in the front.
