Old Thu, June 23rd, 2011, 10:16 AM
SubVet SubVet is offline
SubVet is on a distinguished road
Default Is this tune possible?
OK, since I sort of have an FU chip, could I buy a custom tune with the following features?
I would like to have a couple features on one tune.
1st High Idle (maybe 1100 rpms) until the engine gets to a certain temp, then it would just revert back to a normal idle. I like to let the truck warm up in morning. (I have a blank pedestal
2nd A no drive condition or limit the speed to 5 mph, I like to stop for a coffee in the morning, and I like let the truck idle while I run in and get my coffee, but I think this would give me a little bit of a security feature . I am betting that anyone that would try and steel the truck while it was idling in front of a convent store wouldn’t be smart enough to find the switch. This way I could park the truck overnight with the switch in that position and any potential thief couldn’t get very far or in the morning when I’m letting the truck warm up, I don’t have be near it.
What do you think?
Old Thu, June 23rd, 2011, 11:01 AM
It can be done depending on the truck. What is your PCM code? You would have to use the order form for custom tunes via the internet here: https://fs21.formsite.com/Power_Hung...ure_index.html
Just make sure to use the text boxes to accurately describe what you want to happen.
There is a $50 charge for each custom tune and they will show up in your PhoenixFlash drop-down menu along with the FU tunes you have available. When you have that up and running, that is......
Old Thu, June 23rd, 2011, 11:10 AM
"When you have that up and running, that is......"
NVK2
