Old Mon, August 15th, 2011, 02:54 PM
GTS GTS is offline
Default can't program chip
So I wrote some new programs for my chip and installed them in the chip a day or two ago. I did some more tweeking on the programs and went to load them on my other chip and now the burner won't work. In the Phoenix Flash screen where you select the drop down for each position there is usually a line that says **BLANK** and one that says something like "select file from folder." When I click on the drop down all it says is **BLANK** and doesn't give me the other option.
At the bottom of the window it says it's connected, the PID and CID numbers match, I've downloaded the new update, I've tried uninstalling/reinstalling the software on my laptop and I even tried installing it on my work laptop to see if that would work. Nothing seems to be working! And the part that realy gets me is it worked just fine the first time yesterday.
Anyone had this same issue? What did you find the fix to be? Thanks for your help!
