Old Thu, August 25th, 2011, 02:18 PM
mustang_gt_350 mustang_gt_350 is offline
mustang_gt_350 is on a distinguished road
Default manual shifting with chip
Ok, Id like to make a shifting tune where exampe Position 1 is 1st 2 is 2nd and so on. So I'm guessing on transmission test gear select you pick what gear and on trans test switch you have to have it as 1 for on?
Also how do you disable the TC lock? as i would like to be able to control it manually with my hand switch and not have it on the tune.
I beleive this will make it easier for me to drive/tow with my larger setup, instead of having to pull the shifter down into 2nd and lock the switch I can just flip through the gears with the tune and lock as needed with my switch. Also i may set it up that i can control the shift on the track with the sled with my tune so i can go from 1st into 2nd and not have to worry about it hitting 3rd and dieing out.
Old Fri, August 26th, 2011, 09:25 AM
http://forum.gopowerhungry.com/12569-post9.html
Old Fri, August 26th, 2011, 01:58 PM
Thanks, I couldnt find the original one post
Old Fri, August 26th, 2011, 03:21 PM
Shaw Shaw is offline
Shaw is on a distinguished road
figured it out - dumb question
Old Thu, September 1st, 2011, 06:38 AM
wow, after rereading this thread I realized it might look like I am saying mustangs original post was a dumb question. I should have said in my post that my question was dumb but I figured it out and deleted the post.
I just didn't want any confusion towards Mustang.
