Old Fri, August 26th, 2011, 11:58 AM
thollis thollis is offline
thollis is on a distinguished road
Default Running an FU without an exhaust upgrade
Hey Guys I'm looking at getting an FU chip only question is I haven't upgraded to a 4 inch exhaust yet. It is in the plans but can't buy it all at once. I have installed all the guages (EGT, Trans Temp, Boost) will I be ok just going with the chip for a while as long as I keep an eye on my EGT's I was figureing I would just run the low hp tunes such as 20 hp tow 60 daily driver until I do the exhaust.
Any experience or reccomdations running without and upgraded exhaust
02 F350 Crew cab 7.3L
Old Fri, August 26th, 2011, 12:31 PM
No problem using stock exhaust!
As with any modified diesel you need to keep EGT's in check, but this should not even be an issue.
Old Fri, August 26th, 2011, 05:29 PM
azzuki azzuki is offline
azzuki is on a distinguished road
Mine works great, only exhaust mod is muffler delete.
Old Sat, August 27th, 2011, 04:58 PM
As long as there isnt a cat/stock muffler in the way you're fine.. i can nail 1200* if i try real hard.. but dont worry.. just watch your pyro!
DIY intake
CCV dumped
Autometer gauges
WW/ATS 1.0 exhaust housing
AIH delete/ebpv delete
TruCool trans cooler
Straight piped
PHP FU
Old Mon, August 29th, 2011, 10:14 AM
Alright guys thanks for the input kinda what I figured if I keep an eye on things I should be OK.
