Old Tue, August 30th, 2011, 09:09 PM
guede19 guede19 is offline
guede19 is on a distinguished road
Clap I change my truck
I will change my truck, from a 2004 4.6 2 wd whit 3.55 rear to a 2008 5.4 4wd heavy duty whit 4.10 rear. Iwould like to know if i return the gryphon to stock if il will work on the new truck
thank for all
Ben
Old Tue, August 30th, 2011, 10:31 PM
Canned tunes should work, custom tunes will not.
Old Wed, August 31st, 2011, 10:43 AM
And, to return to "canned" tunes so that your Gryphon will work on the new truck:
1. Set your old truck back to stock (Level 0) BEFORE you remove the Gryphon!
2. Start Pegasus on your PC.
3. Plug the Gryphon into your PC. When Pegasus tells you the Gryphon is "connected", click on [Updates]->[Gryphon Update Manager]. You should see a firmware and a calibration update available. Apply them both.
Now the Gryphon should work on your new truck.
Old Wed, August 31st, 2011, 10:56 AM
The canned tunes will work but new custom tunes will have to be ordered and written for the new truck......
Old Wed, August 31st, 2011, 10:41 PM
tanks you guys, i will check that tomorow.
Ben
