Old Wed, October 12th, 2011, 09:19 PM
ttyR2 ttyR2 is offline
ttyR2 is on a distinguished road
Default Can the Phoenix chip remove PCM checks for things like AIH?
Title says it all. I'm looking at removing the AIH on my truck and using the plug to run a boost gauge. There are options to remove the AIH and replace it with a resistor so the computer doesn't throw codes, but can the Phoenix remove the check completely so I can remove the AIH relay entirely?
Old Thu, October 13th, 2011, 03:23 AM
I removed mine completely.. it throws a soft code but not a visible code unless you plug in a scanner and no the chip wont remove it, but the resistor is easy to use.
DIY intake
CCV dumped
Autometer gauges
WW/ATS 1.0 exhaust housing
AIH delete/ebpv delete
TruCool trans cooler
Straight piped
PHP FU
Old Thu, October 13th, 2011, 03:28 PM
Here's an idea:
Leave the relay and associated wiring intact. You can pull the large gauge red wire off the top of the AIH relay and put it in the glove box. As long as the signal wire is put back on the relay, you won't have any trouble with "throwing" a code.
Old Wed, October 19th, 2011, 09:50 PM
I had been lead to believe that with the removal of the AIH element, the computer would see the fact that there isn't a load. If that's not the case, I should be good to go.
