2009 to 2014 F-150
Old Fri, November 11th, 2011, 03:31 PM
ff0326 ff0326 is offline
ff0326
ff0326 is on a distinguished road
Default Teen Driver 75
Is this option available as a stand alone program? Is it available for '09-'10 F-150 with V-8? I have a fleet with employees who seem to think they are driving a race car Need to put a little woo in their gitty-up.
Old Fri, November 11th, 2011, 05:40 PM
You might be able to do through the speed limiter function of the programmer.....if it goes down that low....or through the use of custom tunes.....I'm sure Bill or Cody might know....
Old Sat, November 12th, 2011, 05:32 AM
RevoErick RevoErick is offline
RevoErick is on a distinguished road
The following is straight from the manual. Hope this helps.
SPEED LIMITER
The Speed Limiter restricts the top speed of the vehicle. Factory speed limit values are generally based on the tolerances of the driveline components.This value may be lowered in fleet situations or when young drivers are behind the wheel. Your Gryphon™ programmer has the ability to remove/adjust your vehicle’s factory speed limiter. Removal/adjustment of the factory speed limiter is intended for use at a closed circuit, legally sanctioned racing environment. Even if racing in a legally sanctioned racing environment, it is your responsibility to ensure your tires and other vehicle components are rated to travel at increased speeds with the speed limiter removed/adjusted. If you remove/adjust the speed limiter during highway driving, it is your responsibility to obey all driving laws, including adhering to posted speed limits. Removing/adjusting the speed limiter for purposes inconsistent with the product's intended function, as stated herein, is a violation of the product’s intended use and invalidates the product's warranty. Power Hungry Performance is not responsible for, or liable for, the consequences of
improper product use.
[/COLOR]
Old Sat, November 12th, 2011, 11:06 AM
SPEED LIMITER
I know the monochrome gryphon and sct SF3/xcal3 can do it but will the CS/ CTS be able also?
BTW....the monochrome gryphon will not work on 09+ f150's.....
