Old Thu, December 1st, 2011, 12:30 PM
BigSur BigSur is offline
Scientist
Default DTC Code Help
My emmision system light came on today. My Gryphon is throwing the following code: P0020 - Intake Camshaft / Position Actuator Circuit / Open (Bank 2).
Any ideas on what may be going on here. Had to replace a battery this week....not sure if it's relative or not.
Old Thu, December 1st, 2011, 12:39 PM
Your altenator may be out the door also.....one of the diodes for the charging cycle in the altenator might be toast and can cause this code.....get the altenator tested
Old Thu, December 1st, 2011, 06:01 PM
Scientist
Okay sounds good. This is one of many things that have gone wrong recently. Might be trading the truck soon, so we'll see. Thanks for the reply.
Old Fri, December 2nd, 2011, 01:17 PM
Its best to find a shop that can use a scope to test it while running....when the dioides start to go the voltage fluxuates and some of the know voltages for certatain sensors aren't there and trigger the codes....
Unfortunately remanned alternators have their diodes overlooked when being rebuilt...the best replacement is a new oem one.....
Old Mon, December 5th, 2011, 08:03 PM
Scientist
Hey 88, I noticed something weird today. Turned a corner, went light on the accelerator, and noticed a slight hesitation with the engine.....sort of "bogged" and then picked back up a few seconds later. Do you think this could be in any way relative to my emmisions light coming on, associated DTC code, etc???? I have plans to get it all checked out....just waiting to get freed up at work.
Old Mon, December 5th, 2011, 08:06 PM
Clean the maf and tb.....
Old Tue, December 6th, 2011, 08:01 AM
Scientist
Actually, that is getting done with my 60k service. I know how to do it as well and will do it myself next time. How often and/or how many miles do you recommend in b/w tb and maf cleaning?
Old Tue, December 6th, 2011, 09:14 AM
I'm anal about it being every 15-20k when the fuel filter is changed.....
Old Tue, December 6th, 2011, 07:37 PM
Scientist
thanks
Old Tue, December 13th, 2011, 03:24 PM
Scientist
Just an update. Took my truck in today to get 60k service done....fuel filter, TB and MAF clean, tranny flush, etc. Even though I wasn't quite ready for the service, I took it in early to have the DTC code checked out....plus I had a screw in one of my tires.
Right before I walked in to drop off the key, I switched back to stock. When I did, it cleared the code....no more check engine light!!! Crazy. Good to go though.
