Old Tue, January 10th, 2012, 08:23 AM
blue72 blue72 is offline
blue72 is on a distinguished road
Default Can you combine high idle and no start?
It was suggested in another forum that I might be able to combine the high idle and no start in the same position. Would this work? I assumed the no start tune would disable the truck whether it was already running or not? Is this not the case? Thanks!
Old Tue, January 10th, 2012, 09:38 AM
tdpower tdpower is offline
tdpower is on a distinguished road
Check this thread and see post #4 from Cody. http://forum.gopowerhungry.com/phoen...ip/5889-a.html Not sure if they would charge extra to make the high idle a no start tune.
Grant -------------2000 7.3 powerstroke. PHP 6 position chip (stock,high idle,60tow,80dd,100hp,no start) autometer phantom gauges (pyro,boost, trans) 6637 filter, AIH delete. Oil crossover(died rest in peace). 6.0 tranny cooler, In tank mods, Wicked Wheel. Walker muffler, Riffraff FRX.
Old Tue, January 10th, 2012, 07:59 PM
When you order you can put in comments and requests. They might do it for you if they are not to busy. Worth a try.
