Old Thu, January 12th, 2012, 11:05 PM
T-Bubba T-Bubba is offline
T-Bubba is on a distinguished road
Default No start... Need advice
I installed my chip. At first it started fine but the chip didn't work. I removed it all and cleaned the contacts some more. After that it wouldn't start. Cleaned it a little bit more and it started for a few seconds then died. If I unplug the chip the truck runs fine and starts right up. I used a brass brush and some emery cloth to clean it. Mine had a lot of silicone on it. Do y'all think that I could be that it's just not making food contact?
Stupid is as stupid does.
02 f250, 7.3,4r100 rebuilt at 140k with shift kit and triple disc. Dana 60, 2.5" zone leveling kit, 16x10s, 315/75r/16
Autoenginuity in the Lafayette,La area
Old Thu, January 12th, 2012, 11:15 PM
Since this is in the FU section, I assume you have an FU chip.
Did you flash any calibrations to the chip initially? They are sent out blank.
Old Fri, January 13th, 2012, 05:27 AM
Yes. I have the fu. I did burn the chip. My high idle did work for a few seconds
Old Fri, January 13th, 2012, 11:00 AM
Sounds to me like there is something amiss between the chip and the PCM circuit board if it worked at some point.
Old Fri, January 13th, 2012, 06:04 PM
I got it. Took the PCM out today and in the sunlight I could tell that it wasn't clean enough. Scraped some more silicone off with a toothpick and passed some scotch bright over it after to finish. Working flawlessly. The power from this chip is unreal. Feels like a new truck
Old Fri, January 13th, 2012, 11:20 PM
I'm currently making a video of how to clean the connector right the first time!
Old Sat, January 14th, 2012, 12:18 PM
That's good man. Doing it in te sunlight vs in the shop with a flashlight helped alot
Old Tue, January 17th, 2012, 03:30 PM
Brass Brush is the ONLY way to clean it right the first time IMO.
DIY intake
CCV dumped
Autometer gauges
WW/ATS 1.0 exhaust housing
AIH delete/ebpv delete
TruCool trans cooler
Straight piped
PHP FU
