Old Thu, January 19th, 2012, 09:15 PM
rrkaunis rrkaunis is offline
rrkaunis is on a distinguished road
Default Do tunes have EBPV control?
I just ordered a phoenix chip today and I was wondering how the tunes would affect my Exhaust Back Pressure Valve. I assume the High Idle tune will keep it closed, but will the performance tunes keep it open at all times? The EBPV is a pain and makes me lose control in the ice and snow with the sudden acceleration burst when it opens and deceleration when it closes. If a constant fully open EBPV feature isn't part of the Daily Driver or Performance tunes, how much might it cost to have it put into the tune?
Thanks for any advice
Truck: '95 F250 with manual transmission, stock except 3" dp to 5" straight pipe & 6637 air filter.
Old Thu, January 19th, 2012, 09:58 PM
I just ordered a phoenix chip today and I was wondering how the tunes would affect my Exhaust Back Pressure Valve. I assume the High Idle tune will keep it mostly closed, but will the performance tunes keep it open at all times? The EBPV is a pain and makes me lose control in the ice and snow with the sudden acceleration burst when it opens and deceleration when it closes. If a constant fully open EBPV feature isn't part of the Daily Driver or Performance tunes, how much would it cost to have it put into the tune? My truck doesn't have any major mods so I got the $295 version. Also, I joined the forum after filling out the order form in case that matters.
Old Thu, January 19th, 2012, 10:53 PM
All of it will still act like stock.
If your exhaust backpressure valve is still closing even when your engine is hot (warm won't cut it in the winter), then your truck has problems. Either make a longer trip to work or just unplug the backpressure valve.
It can be fixed in the tuning though. However, just unplugging the valve works for most people. It doesn't really do much of anything as far as warm-up times are concerned anyway....especially on a 95-97 that doesn't "idle-up" when cold.
Old Thu, January 19th, 2012, 11:28 PM
I would unplug it but its averaging about 5 degrees here lately and it really helps with the warm up. Earlier today I put in an order for a chip, is it possible to have the problem fixed in the tunes that will be on the chip(with the exception of high idle)? There wasn't an option for that in the ordering process but I would really like the valve to stay open. How much extra would it cost?
Old Fri, January 20th, 2012, 12:35 AM
Its going to work just like a stock file would.
I too am growing to dislike the way the programming is setup from the factory. Never really had an issue with it because my other truck had it removed a few weeks after I bought it. But now that I am driving my dually daily, it is really starting to bug me.
Bill will be able to "relax" this function for ya! Or, you could just unplug that sucker.
Old Fri, January 20th, 2012, 10:12 AM
I don't know what (or if) Corey will charge you for that when you're invoiced.
Old Fri, January 20th, 2012, 10:20 AM
Two threads merged.
I have been running my 95 with the EBPV effectively turned off for the last 5 months. I just turned it back on but changed it so it's never on above 1100 RPM....heck, it even comes on at an idle now. I'll probably leave it that way.
Old Fri, January 20th, 2012, 08:07 PM
Mines gutted and gone, that pos was irritating and I agree it did little to nothing to help warm up, regardless.
DIY intake
CCV dumped
Autometer gauges
WW/ATS 1.0 exhaust housing
AIH delete/ebpv delete
TruCool trans cooler
Straight piped
PHP FU
Old Sat, January 21st, 2012, 07:13 PM
So the note that I got from Corey yesterday concerning the order.......
Not real pleased with that.
However, your tunes call for no exhaust backpressure valve actuation.
Old Tue, January 24th, 2012, 01:46 AM
Two threads merged.
Whoa, that was weird!
Think I need to set up mine like that very soon.
