Old Wed, February 1st, 2012, 02:19 PM
progrezzive1 progrezzive1 is offline
progrezzive1 is on a distinguished road
Default upgrading wheels
i have 2006 mark lt and want to put 24' wheels on the truck do i need to get ant custom tunes once i purchase my gryphon from php or will it compensate by its self to the bigger wheels
Old Fri, February 3rd, 2012, 03:37 AM
Project Pat's Avatar
Project Pat Project Pat is offline
Defense & Security PM...
Project Pat is on a distinguished road
Within the Gryphon you can adjust for rolling diameter changes without having to utilize custom tunes. However, I would most certainly look into getting some custom tunes to balance out the performance aspect that will be effected by the larger diameter wheels. Just my $.02...
04 F150 4.6L / 04 Excursion 6.0L
Old Thu, September 20th, 2012, 09:10 PM
Default 2006 lincoln mark lt
i wasnt sure if the gryphon would work on my truck can someone help me out with this.
Old Thu, September 20th, 2012, 11:32 PM
24 ft wheels will require more than just a custom tune!
Seriously, though, you'll have to ask PHP about using one of their programmers on your truck. I THINK you can do it, but Bill would be the one to tell you.
And yes, with a programmer, you should be able to correct the speedometer, odometer and shift speeds for 24" wheels. What diameter tires are you going to mount on those big feet? Have you lifted the body to allow room for them? If they're too big, you'll need to regear the rear axle (front too if it's a 4x4) or you'll have no power at all.
