Old Tue, February 28th, 2012, 12:14 AM
diefree64 diefree64 is offline
diefree64 is on a distinguished road
Default Question for Cody
Hey Cody,I have an FU chip for my 95' f250 and I also have a 96' f350 with a NAW4 pcm my 95' has a reman pcm with no code on it can I and should I swap them befor I sell the 96'.Thanks for your input.....Jim.....
Old Tue, February 28th, 2012, 08:07 AM
If they're both automatic-transmission trucks (NAW4 is an automatic code), I would say that the chip will work with either PCM.
However, if it gives you peace of mind, by all means, swap them out! It's not that there's anything wrong with a reman. In all honesty, a lot of the cores that people send parts houses when they buy new PCMs have nothing at all wrong with them.
People are WAY too quick to suspect a PCM problem right off the bat and replace it just to find out that it didn't fix the problem.
Old Tue, February 28th, 2012, 09:35 AM
Thanks cody,I dont have a problem,just looking to get the best stuff for the truck I'm keeping......my 95' shuts down the injectors at no load,the 96' does not that is what I am trying to eliminate,if that is even controlled by the PCM??? By the way the chip works flawlessly.....Thanks for your quick reply....Jim.....
