Old Wed, March 7th, 2012, 08:59 PM
yngbuck19 yngbuck19 is offline
yngbuck19 is on a distinguished road
Default Fast shipping
Very happy with how quick my Phoenix chip got here bravo!
I removed and cleaned my PCM tonight going to try it out soon after I get my efuel back together and PCM back in.
I took the PCM covers off and I only used paper towels Qtips and a little alcohol to get the initial greasy stuff off and took out the 5x glass to inspect and there was alredy some copper showing so I took my finger nail and used it to scrape the silicone off both sides and polished with the scotchbrite cleaned with alcohol two times with Qtips and sealed it back up lightly tightened cap screws inserted chip with switch connected.
Old Thu, March 8th, 2012, 07:11 AM
Would it help to put any dielectric grease on the J3 connector should I be concerned with the tiny bit of copper showing but the chip still goes on tightly.
Those are my two questions right now
Old Thu, March 8th, 2012, 07:53 AM
DO NOT put anything on the contacts.
As long as you use a piece of tape to hold the chip in (don't stretch the tape or make it tight...just enough to hold the chip in), you shouldn't have an issue.
Old Thu, March 8th, 2012, 06:01 PM
Thanks for the reply I'll probably use some heat tape from work it won't leave any residue and is super sticky.
