Old Wed, March 14th, 2012, 06:55 PM
Aurora Aurora is offline
Aurora
Aurora is on a distinguished road
Default 07' 5.4 Rattle and Burp
Gents,
After backing up my trailer again this evening I got what has been a recurring issue. Every time I have to back up my trailer without fail the truck will start rattling and act like the engine is going to jump out of the hood. Turning the truck off and back on instantly fixes the issue but that's a poor excuse for a solution.
I've also began to notice that while in part throttle, mostly in low speeds, I can hear a faint, one second or less, burp from the exhaust as if for a second the fuel and/or ignition forgot what was going on for a moment. This is all while keeping a relatively constant throttle position.
I don't know if these are Gryphon related issues or if this is a ford related issue, but any help would be appreciated.
Thanks!
Michael
07' FX4 Screw | White & Gray | Custom True Duals | DWV Intake Mod
Old Thu, March 15th, 2012, 11:01 AM
Originally Posted by Aurora View Post
Gents,
Thanks!
Michael
I cannot imagine how this could be tune related, but you could try returning the tune to stock and see if the problem(s) reoccur.
Backing a trailer is such a low speed, low power operation that it hardly seems possible for the tune to have any effect whatsoever. I wonder if you possibly have a dragging electric brake in the trailer wheel? I had that on my trailer (actually the brake mechanism broke) and pieces would "catch" in the wheel causing it to bind while backing. Moving the trailer forward and then resuming backing would free it. But, the permanent fix was a brake replacement, which I did.
Do you hear any noise in a trailer wheel when it is rotated by hand, forward and backwards, with the trailer jacked up?
Old Thu, March 15th, 2012, 03:34 PM
Any codes?
Do you have access to a scanner that is capable of reading VCT pids?
