Old Fri, March 23rd, 2012, 09:05 AM
RGSMDNR RGSMDNR is offline
RGSMDNR is on a distinguished road
Default Did my HEX code change?
I had my truck in the shop getting some tranny work done. I had reverted my programmer to stock before i dropped it off. A while after I got the truck back I tried to program it... and it didnt work. Said something about the HEX code not compatible.... so now what?
Old Fri, March 23rd, 2012, 10:16 AM
checked my HEX code and it didnt change, so Im not sure why i got an error code...
Old Fri, March 23rd, 2012, 01:17 PM
So, you are able to retrieve your hex code using the Gryphon? That sounds like the unit has initialized correctly. Possibly, your battery is weak. Could you put it on a charger for a while until it shows fully charged? If so, once the battery looks good, try reprogramming.
If this doesn't work, you MAY have a corrupted file in the Gryphon. If it's the monochrome Gryphon, try reloading the firmware/software using [Updates]->[Gryphon Update Manager] then reload any custom tunes you have with [Updates]->[Custom File Download (Internet)]. If it's the CS/CTS model, you can update firmware/software by plugging it in to Fusion on your PC, but that will wipe out any custom tunes you have and Bill will have to set up a download package on the Fusion server for you to get them back.
Old Mon, April 9th, 2012, 09:53 PM
Tried to program after driving for a while... everything went ok. Maybe it was the battery that was low??
thanks!
