Old Fri, April 6th, 2012, 02:52 PM
God & Guns
Default Replaced ebps...got codes
Just replaced my EBPS I got from RiffRaff. I followed guzzel's instructions. I think one of the codes I had was one I had before P0380. Other codes are P1536 and P1464. Forget what P0380 is, but just read the other 2 has something to do with the A/C and the other has to do with parking brake circuit. The A/C clutch kept engaging and disengaging....thought I was hearing a relay at first. Also the EBPV actuated a couple of times. I could disengage it with the brake pedal and it eventually quit doing it after it idled for a couple of minutes. All codes still present after turning A/C off and making sure the parking brake was disengaged. Parking brake has never worked since I had it and A/C would come and go since last summer. These 2 codes are fairly new...its been MAYBE a month since I last checked my codes and they were not there then. Forgot to check EBP, I will go do that now and post back. Codes are being pulled and cleared with my Aeroforce Interceptor.
EBP at idle is 14psi. Lot better than 30psi with the old sensor. Tried to pull codes again but the gauge said it was unable to complete the action...so maybe I don't have codes? Gonna get with AeroForce tech and see if is what that means.
Just disconnected the batt's to see if anything needs to reset.
Old Fri, April 6th, 2012, 05:49 PM
God & Guns
Hooked batt's back up and fired the truck up. Pulled P0306...think that's a mis-fire code? Cleared it and it didn't pop back up. Ran the truck down the road and back...a little WOT. Got back to the house and still not pulling codes : ). Still curious about that A/C code. I haven't tried turning it back on. But I'm curious what that code is...maybe what is keeping the A/C from working.
