Old Fri, April 20th, 2012, 10:35 PM
ttyR2 ttyR2 is offline
ttyR2 is on a distinguished road
Default Phoenix install question
Picked up my Phoenix chip this morning and installed it after cleaning the PCM contacts very well and tinning the contacts on one side (which brought the board thickness up to exactly 0.062"). I notched the plastic carrier for the PCM so that the cable would stick out without being crushed and then slid the PCM back in to the carrier. Does the carrier actually put any pressure on the chip? Or is there a gap and that's why you need to use the tape?
I didn't have any gaffer tape to tie the chip down with so used a small piece of non-styrene foam temporarily.
The Phoenix really made my truck come alive! It's awesome.
