Old Mon, April 23rd, 2012, 03:44 PM
cnaegle cnaegle is offline
cnaegle is on a distinguished road
Default 2004 F-150 Upgrades
I am new to the forum and new to modifying my existing vehicle. I have a stock 2004 F-150 5.4 4X4 SuperCrew (117K miles) that I have had since it was new. It runs very well, but does have the "ticking" I think if most likely a cam phaser issue. I don't know whether to try to get that fixed now as a priority or not. I plan to use seafoam, I know there so debate on whether it's good or bad.
I want to improve performance on my vehicle now. I have also purchased a 28' ToyHauler. The improved peformance is needed to help with that and I'd just like to have the performance when needed.
Right now I'm looking at the Gott air mods and a Gryphon.
I appreciate everyone's help and advise.
Old Mon, April 23rd, 2012, 06:37 PM
Don't use seafoam. On this forum it has never been a debate. You could probably mix it yourself for half the price. I'm not saying it isn't bad, it has it's uses, but there are many products that are better. I like B12 chemtool and 88Racing likes Techron. IIRC the techron is one notch better but I have never used it.
Clean the MAF sensor, throttle body and change out filters.
A better drop in air filter might help some also, we generally recommend staying away from the oiled filters. The market has had a recent influx of higher performance dry filters. I'm running the Amsoil one that has shown to be a good middle ground between the thick paper stock one any the oiled K&N filter that traded filtration for air movement.
Definitely do the gotts mod.
Old Wed, April 25th, 2012, 03:34 AM
How often will you be towing? I know the 4x4 came with 3.73, might want to look into 4.10, depending on your tire size, lift, and towing plans.
Also, a complete exhaust system(headers back), intake, and a great tune will give you some good power gains.
e-fans also eliminate some drag (known dyno tested to improve 7-14hp)
Old Wed, April 25th, 2012, 11:26 AM
Thanks for the feedback.. I probably will tow 8 or 10 times a year for now.
