Old Fri, June 1st, 2012, 02:08 PM
rodolan rodolan is offline
rodolan is on a distinguished road
Default Bought used gryphon(file missing update required)
I bought a used gryphon and when I try to load it, it shows file missing update required RXDE5D2. The guy I bought it from said it was returned back to stock and I had dealership return my truck back to stock a couple weeks ago when I had trans problems. Any suggestions...
2003 f-250 PHP ficm no cat or muffler egr block
Old Fri, June 1st, 2012, 08:41 PM
I'm confused. You had a dealer return your truck to stock? Was it tuned by some other programmer? Is the Gryphon you bought one that works with pre-04 model year trucks? Does the Gryphon still have custom tunes loaded in it? (They won't work on your truck.) Have you downloaded Pegasus and performed a "Gryphon Update" on the programmer to clear any custom tunes?
It sounds like the Gryphon you have does not recognize your truck's .hex code (RXDE5D2). And, since you have an 03, that code cannot be a new one.
Old Fri, June 1st, 2012, 10:20 PM
I had trans work done so the dealer reprogrammed my ecu before I bought the tuner and the tuner I bought don't have custom tunes, I checked my calibration # and it starts with a 1. The tuner came off of the same year truck as mines, I didn't update my profile I now have an 07 FX2 with the 5.4 I've been reading a lot and it looks like I will have to install pegasus and do the update, although that's all Greek to me.
Old Sat, June 2nd, 2012, 12:26 PM
It's not "rocket science". Download the Pegasus client from the "Support->Downloads" link on this page: Power Hungry Performance - Feed your hunger for POWER! (the first link in the downloads window). Install it on a Windows PC (doesn't work on Macs). Once it's installed, start it and THEN plug your Gryphon into the PC using a USB cord. Hopefully, Pegasus will report that the Gryphon is "connected" and the Gryphon screen will change from red to green.
Then, click on [Updates]->[Gryphon Update Manager] to install any firmware/software updates to the Gryphon that are needed. When the process finishes, take the Gryphon back to your truck and, with the ignition ON (engine off) plug it back in. Hopefully, it will show you your truck's hex code. If it does, you should be good to go.
You might think about changing your signature - that's why I thought you had a 2003.
Old Sat, June 2nd, 2012, 08:11 PM
Thanks I'll give it a shot. I haven't been on this site in a while forgot about changing my sig. Thanks again....
Old Sat, June 2nd, 2012, 09:11 PM
Done the download now it works. Thanks again now if I can figure how to change my signature lol
Old Sun, June 3rd, 2012, 07:25 PM
Good to hear. (I'll let you figure out how to change the sig).
