Old Thu, June 7th, 2012, 08:51 PM
rthammer rthammer is offline
rthammer is on a distinguished road
Default Injector not firing
Hello,
This is only my second post, I got in trouble for my first.
I received my TS chip on Monday. I originally purchased it from TDP. I bought it when I converted my split injectors to single shots. I have had trouble with the truck smoking when I start it up. It smokes like crazy until normal operating temps, or if I head down the road, it stops after the first quarter mile or so.
Local diesel shop tested and said number 7 injector wasn't firing upon startup.
I talked to Jim from Rosewood, whom I bought my injectors from, and he said all his warranty work is single shot conversions. He offered to replace the injector, but said a good tuner should be able to fix it. So I sent my chip to PHP after getting no response to my emails @ TDP.
Well, after retune, injector is still not firing when cold, smokes like crazy.
Was Jim Rosewood right?
Did I just waste $300 retuning?
What should I do next?
My truck is a 2002 Econoline Superduty Extended with 174K.
Old Fri, June 8th, 2012, 09:46 AM
You wasted $300 because a tuning issue won't cause a single-cylinder misfire.
Old Sat, June 9th, 2012, 11:30 AM
Thanks for the reply. I had described my problem to Cody at PHP and Jim Rosewood. I was left under the impression that tuning was the next logical step. I guess a new injector should have been the next step?
Old Mon, July 2nd, 2012, 12:25 AM
Well,
I ordered another injector from Rosewood. Took it to local diesel shop. They pulled drivers side valve cover, since #4 was missing on cold start up, and checked compression. Came back as follows:
#2 350
#4 330
#6 360
#8 340
Are these acceptable numbers? Shop said they were borderline and could be reason for misfire. Notice 4 is lowest. Truck still smokes and #4 misses on cold startup.
Thanks for any advice!
Old Wed, July 18th, 2012, 12:07 AM
Appreciate any responses. Trying to figure out future of this truck.
Old Wed, July 18th, 2012, 01:51 AM
INFRNL INFRNL is offline
I do not recall the limits, but your numbers look fine
Old Wed, July 18th, 2012, 07:56 AM
Those numbers are at the VERY LOW RANGE of being acceptable. If those are "warm" numbers, they are low and will cause problems with a cold engine. The cold limit for a lot of diesel engines is 300 PSI and the warm numbers should be much higher than that (380-400).
