Old Tue, August 21st, 2012, 06:22 PM
bk78 bk78 is offline
bk78 is on a distinguished road
Help just about a happy camper
I'm just about there. i received my tunes today but i can't seem to update my edge programmer. HELP PLEASE!!!!! when i click install it says error contact PHP.
thanks in advance Brad
Old Tue, August 21st, 2012, 08:21 PM
Anyone?
Old Tue, August 21st, 2012, 10:12 PM
CaptFX4's Avatar
CaptFX4 CaptFX4 is offline
Learjet Driver
CaptFX4 is on a distinguished road
BK78
I saw where you posted at 11 ish and said you ordered your tunes on June 24th and its been about 60 days with your expected ship date of July 22.
How were you notified they were done? I ordered on June 24th as well with an expected ship date of July 19th. Nothing for me yet.
I have seen where they are very busy at PHP and I haven't tried to call, I've just let things happen as they will.
Are you connecting through Pegasus?
Old Wed, August 22nd, 2012, 02:10 PM
Here is a checklist,
1) Make sure the internet connection is good and does not have a shared load from other processes. Some people are like me and still using various kinds of telephone based hardware.
2) Make sure nothing else is running on the computer. Splitting computational capabilities will usually cause things to time out on Pegasus.
3) Issues are also caused by firewalls
4) In Pegasus, see if you can use the Pegasus Update Manager, if that works everything mentioned before this are good. If not, Bill needs to get involved as it may be a serial number/target issue.
Old Wed, August 22nd, 2012, 05:32 PM
I got that all figured out but when I was installing the programmer on my truck last night my battery died in the middle of it and when I bought a new battery today my programmer is blank and won't do anything. Did this fry my programmer? Since it was not done installing is there anything wrong with my trucks computer now? It stalls out at red lights now? Please help if you can Longshot270
Thanks Brad
Old Wed, August 22nd, 2012, 06:27 PM
Wow, you are lucky you could crank the truck.
When you say it is blank, does it light up? Was the programmer plugged in when you reconnected the new battery?
Old Wed, August 22nd, 2012, 06:39 PM
Programmer wasn't plugged in when I connected the new battery. It lights up just nothing on the screen. I sat in my truck for over a hour waiting for the tunes to load and all my programmer said was "reading PCM" for over a hour the battery died.
Old Wed, August 22nd, 2012, 07:33 PM
Try disconnecting and reconnecting with the key in the "On" position. If that doesn't work, plug it into the computer and see if Pegasus recognizes it.
Old Wed, August 22nd, 2012, 09:14 PM
Pegasus won't recognize it. And my truck is stalling out when I come to a stop at a light. The programmer is not in my truck. Should I post in the emergency section ? I don't want to screw my truck. Should I get it re flashed by ford? All this for just trying to add a few extra HP.
Old Wed, August 22nd, 2012, 09:17 PM
Go ahead and post in the emergency section with as much info as possible. You probably won't need to get reflashed.
