Old Sat, September 15th, 2012, 02:59 PM
boto boto is offline
boto is on a distinguished road
Default acceleration: 2wd or 4wd?
Has anyone compared 0-60 or 1/4 times between 4wd and 2wd? Just wondering; newbe here who has never run in 4w high to check. Shouldn't hurt it, should it?
Old Sat, September 15th, 2012, 05:22 PM
You shouldn't operate the truck in 4WD on a hard-surfaced road, because it makes the handling "squirrelly" which could lead to a nice crash. So, if you compared the times on a dirt road, you're probably OK. But, this wouldn't really tell you what you're trying to find out, since 4WD would probably minimize slip on the dirt road.
I think 4WD gives you more mechanical losses though, so I doubt if you'd see better performance if you did successfully test on pavement.
Old Sat, September 15th, 2012, 06:10 PM
I know a few people who launch in 4wd and say it improves their times...but they are running transmissions built for the abuse.
Old Sun, September 16th, 2012, 11:09 PM
I have heard that they are better times, but only if you lose traction off the line. The bad thing is you probably shouldn't go that fast with the front wheels engaged. Most shouldn't be engaged about 50mph or so, check out the owners manual to be sure, I forgot what the exact number is for your truck.
