Old Tue, October 23rd, 2012, 11:27 AM
Kronic Kronic is offline
Kronic is on a distinguished road
Default Mods/tuning
I know this has been beat to death over the years, but there are also millions of combinations out there as well. I'll start with history on the truck:
2002 7.3L, 385000 KM, was bone stock when I bought it at 311000 KM, drove for a year then added all the mods below (i also have gauges already). I use the truck as a DD, tow, work, family etc. Due to my job I end up pulling more than the average person through lots of conditions. What I have run into is high EGT's (I back out at 1200 deg. to keep the engine from burning up). So I'm planning on adding water meth this spring to help with the EGT issue. I also would like to add a Phoenix chip to it was well. Now another note I do not know when/if the injectors have been changed. The truck runs great, but i have noticed it starting to idle a little rougher lately (possibly lazy injector). So if I have to change out injectors I'll more than likely go stage 2 single shots as well.
Any input on this combo for what I'm doing.
Also I don't race, sled pull, mud bog or anything like that, been there done that, don't need to anymore LOL,
Kronic
2002 F350 CC/LB/SRW, 7.3 PSD, 6spd, 4x4, 6637 intake, IH up pipes, straight pipe, WW, FRX, HPX, CCV mod, EBV Exh. Brake, gauges
Old Tue, October 23rd, 2012, 08:05 PM
PS would like to be 350+ HP as a final goal. I know what I have mentioned so far more than likely won't get me there.
Kronic
Old Tue, October 23rd, 2012, 10:24 PM
If you're running into high EGT now, you better find out what the problem is before you start adding more fuel.....because EGT only goes up from here.
Old Wed, October 24th, 2012, 08:18 AM
God & Guns
Yea, what he said. IIRC, I have a hard time hitting 1000* in stock. As for a rough start/Idle, does it get better as the truck becomes warmer? Is the truck plugged up? Reason I ask, it could be from cold thick oil. Many diesel owners switch to lighter and/or synthetic oil for this reason. Before you get to that hp, you will need to beef up the transmission....now or later. Make sure you EBPV is open all the way. It being slightly closed will cause higher EGT's.
Old Wed, October 24th, 2012, 10:46 AM
I have been running 5W40 full synthetic on it, just serviced it though so we'll see if it makes a difference. Truck hasn't been plugged in yet this winter, it has been getting colder but anything below -10C I plug it in. Its not as bad once it warms up.
EGT issue is only when I'm pulling a hill loaded. Empty I couldn't even get close to 1200. Cruising on flat ground with a trailer usually sits at 800F, without trailer 600F. It does take a good hill to hit 1200F with a trailer behind.
Kronic
Old Thu, October 25th, 2012, 09:44 AM
God & Guns
Kronic
Empty and cruising EGT's sound normal. I don't pull anymore and deffinately dont have hills around here.
