Go Back   Power Hungry Performance Forum > Power Hungry Performance Product Information > Hydra Chip 17-Position Chip > FAQs - Hydra Chip 17 Position Chip
FAQs - Hydra Chip 17 Position Chip Instructional Videos and Tips for installing your
Hydra Chip as well as the HydraFlash software.
Old Thu, October 22nd, 2020, 10:51 AM
Default What is the Hydra Chip?
The Hydra Multi-Position Chip is a feature packed, high quality, low cost alternative to many of the existing modules on the market today.
• Starting at $295 - And holds up to 15 Standard or Custom Calibrations!
• Custom calibrations are $50 each
• Hydra Chip installation kit includes chip, switch, ribbon cable, USB cable, and brush to clean the PCM connector
• An optional extension cable and mounting bracket may be purchased separately for customers who wish to program their chip without removing it from the PCM
• 17 TOTAL POSITIONS including built-in Module Bypass (for diagnostics) and No-Start
• Easy to read TWO DIGIT removable display switch that mounts on any flat surface for maximum convenience
• Optional dash-mounted USB cable for permanent installation
• Supports most competitors’ calibrations!
• Fully compatible with PATS-equipped vehicles
• Update and Reprogram ONLINE using our FREE HydraFlash™ software
• Choose from our extensive library of standard calibrations
• Program and Verify ONE or MORE positions with one click
• Program calibrations in ANY POSITION(s) — or leave ANY positions blank!
• A single position takes less than 20 seconds to Program and Verify
• Reprogram without removing the chip from the PCM
• Read the factory PCM calibration directly through the chip
Please see our website or Facebook page for more details!
If you are interested in becoming a Hydra dealer, please note:
Dealers must have a store-front or an online retail website and be able to provide a valid Tax I.D. number.
Please contact angela@phptune.com for more information about becoming a Hydra dealer.
Tags
cable, chip, hungry, hydra, hydraflash, library, multi, position, power, ribbon, switch
