Old Tue, May 10th, 2011, 10:23 PM
wchamp7 wchamp7 is offline
wchamp7 is on a distinguished road
Default new Gryphon
i just got my new Gryphon programer in the mail and when i plug it into my truck it doesnt light up or do anything but when i plug it into my computer it lights up red thats it. what am i doing wrong or whats wrong any help thanks?
Old Tue, May 10th, 2011, 11:02 PM
Check the fuse in your truck that runs the cigarette lighter. It also runs the power for the OBDII port.
Have you downloaded Pegasus? You will have to have that successfully installed before you should plug the programmer into the computer.
Old Tue, May 10th, 2011, 11:16 PM
yeah my cigarette lighter doesnt work i will replace that fuse and see if it will work!
Old Wed, May 11th, 2011, 02:21 PM
Yep...that darn fuse....
Old Wed, May 11th, 2011, 03:13 PM
And to the OP: It sounds like you may have plugged the Gryphon into your PC BEFORE you installed Pegasus? If so, Pegasus will possibly not install properly. You may have to do a "driver uninstall" that I talk about here: http://forum.gopowerhungry.com/faqs-...tallation.html
If Pegasus can't connect to your Gryphon when you install Pegasus, you'll need to follow that procedure.
