1997 to 2003 F-150
  #15
Old Thu, September 17th, 2009, 10:18 AM
RobbyMartin RobbyMartin is offline
RobbyMartin is on a distinguished road
Ok
From my understanding of tuners/programmers is this.
Once the pcm is flashed with a new tune it cannot be removed unless reflashed.
I assume the Hypertech has the same proceedure as the gryphon.
So by removing the battery, the pcm's memory has not been altered due to the pcm's flash memory.
However the Keep Alive Memory resets and sends a p1000 code and the only way to get rid of this is by the drive cycle reset. This takes 50-100 miles.
The gryphon only takes about 5-10 min to program initially. But when you get one with custom tunes only about 2 minutes.
OK, so here's my next question. If I remove the Hypertech program manually and there is no pause/lag by no longer having it installed, will I be dealing with the same issue if I get the Gryphon? I will go crazy if I get the Gryphon and I still have the same issue with pause/lag.
